IMDB Batch script?
IMDB Batch script?
Hi there!
Been browsing through the forum... been a year since i installed antp's software again (was out of the loop for a while).
Read about IMDB being changed and all that...
Though... i can't find the imdb batch file anymore, though it's in the directory list.
Any suggestion?
Does it still work?
I downloaded the updated version into the directory, but it doesn't show in the available scripts.
Please advise
...dukesbury
The batch version only appears when calling the window from Tools -> Scripting.
Be sure that the file is in the Scripts folder, and as the ".ifs" extension (and not a ".txt" after it, that may be hidden if your Windows hides extensions of known files).
Found it! Thx for the fast reply :grinking:
I was wondering if the 'large pic with batch import imbd' script is fixed? thanks for a great program!
It is fixed like the other IMDB scripts, but it still has some problems for finding pictures due to the link to do with Amazon.
Usually the large picture exist on IMDB but it is really not easy to find it by script since it is mixed with other pictures from the movie.
I have to rewrite this IMDB script to try to get this picture, and to try to clean the Amazon search.
But I do not know when I will do that.
