gast
Post
by gast » 2004-06-22 09:34:17
Hi!
is there the possibility the movie lengthens in hh:mm:ss to indicate?
Wikky
Posts: 9906 Joined: 2002-05-30 10:13:07
Post
by antp » 2004-06-22 09:43:14
Not for the moment.
Maybe later, but I do not promise it.
gast
Post
by gast » 2004-06-24 05:54:30
thanks for the answer, that is only why I the that do not use. I use up to now exel-table
Zephura
Posts: 5 Joined: 2004-09-08 13:20:59
Post
by Zephura » 2004-09-08 14:40:25
I don't know how antp make it, but
could you define the field Length as string whereas as integer in the Delphi sources ???
if yes, it is a child play to transform a length in minute into the hh:mm format
(if you can use the geometric fonction, it will be easier)
(transform of y°yy'yy'' x,xxxx°)
Post
by antp » 2004-09-08 14:56:35
The problem is not for converting the string, but that it is annoying to manage in scripts, importation, templates, etc. if the format is not fixed.
