AMC 3.4.3 IMDB Batch Scrip: No image retrieved now?
Why?
because the site changed
you could check the recent topics, there are already few ones about that :p
viewtopic.php?t=1351
thank you very much.
I have update my script and re-import the movies, but the picture does not show any way... :??:
for which movie ? are you sure that you overwritten the existing scripts (i.e. did you put the files in the "scripts" folder) ?
Yes, I DO put these updated scripts in the 'Scripts' folder. And I also tries to copy and paste the contents of the scripts into the old one. But neither way could make me to retrieve the pictures -- unfortunetly for any movie ...
And the 'pic' version of imdb scripts (not batch version) still works fine with pictures.
That's strange ; I thought I corrected the batch script.
Well, here is a version that works :
http://antp.be/temp/scripts/IMDB%20(batch).ifs
(I re-uploaded it at the same place than the old one)
Woooo, this version WORKS! Thank you so much!
Link isn´t working, can someone post a working link please?
The link does not work because this version of the script is included in latest AMC versions
