wrong movie page on imdb
koivu2
Post by koivu2 »
Thanks for this program,my problem is sometime i got a wrong adress web with some movies on imdb(give me a page of an other movie) i got Version 3.4.3,thanks.
if you do not say for which movie it fails, I cannot correct the problem...
I posted there a new version of the script that corrects some problem :
http://www.antp.be/temp/scripts/
(when I've few time I will include it with the program, but until then you can manually download the scripts from there)
3RAb
good fix
Post by 3RAb »
i had same the same problem. but your new scripts fixed it. thanks, please do include them in future releases.
sure, it'll be included next time I update ;)
