IMDB[US] script not working anymore ?
Alternate
Post by Alternate »
Well yesterday i install this wonderful software ... try it out for a bit ...
Today i run it again to make my movie database and the IMDB[US] (whatever picture) script is not working anymore !!!
It finds the movie but doesn"t get any info at all ...
Did IMDB change something overnight or is it just me ?
thx for any suggestion :)
IMDB just changed something on their site :(
I am working on the script, there should be an update today.
thx for the update :)
there are still some problems though ...
small pictures are not downloaded most of the time and the comments are screwed up sometimes (ex: try 13th floor)
I saw this problem
for the comment simply, in the script, locate the line that looks like "FindLine('Summary:') and add a <b> just before Summary (after the quote)
For the picture I will have to modify the program. Images that do not work are those that come from amazon.com
These have a .gif extension but they are jpeg
so even if the script is correct and the pictures downloaded they will not be displayed
I will correct that within few days
