Remove Dead Files
klopati
Remove Dead Files
Post by klopati »
Your software is excellent.
I have a dumb question -- what does "Remove Dead Files" do?
Thank you.
it removes from the list the files that do not exist anymore on the disk (e.g. because you moved/deleted manually some files after the renaming process)
