How can I display entires alphabetically?
Hello
Currently I'm using this template....
Full
<html><head>
<LINK REL="stylesheet" href="movies.css" TYPE="text/css">
</head><body>
<table border="1" cellspacing="0" cellpadding="0" width="99%" align="center"><tr>
<td>
  <table border="0" cellspacing="0" cellpadding="5"><tr>
  <td nowrap>Title</td>
  </tr>$$ITEM_BEGIN<tr>
  <td class="lgt"><a href="$$ITEM_FILEINDIV" target="rightfr" class="lgt">$$ITEM_FORMATTEDTITLE1</a></td>
  </tr>$$ITEM_END
  </table>
</td>
</tr>
</table>
<p>Last update: $$DATE. Total: $$TOTALMOVIES series</p></body></html>
Indiv
<html><head>
</head><body class="moviecard">
<table class="lgt" cellspacing="0" cellpadding="5">
<tr><td class="lgt">
<table class="i" border="0" cellspacing="0" cellpadding="1" width="100%">
<tr>
  <td colspan="3" class="iblk"><div class="title">$$ITEM_FORMATTEDTITLE1</div></td></tr>
<tr>
  <td class="iwh" rowspan="5" width="120">$$ITEM_PICTURE</td>
  <td class="igr">$$ITEM_DESCRIPTION</td>
</table><hr class="blk">
</tr></td></table></body></html>
Now.. My problem at the moment is that my entries aren't being listed alphabetically in the main page. This is after I do a HTML export...
Could someone show me what settings I need to change to have it listed alphabetically automaticly?
Right now... I have to manually change the Nr. in the database in a sequential order base on the title name, in order to have it show alphabetically after I export... At the moment.. Its easy to do.. Since my database only has less than 5 entries... But I imagine its going to be tough once I hit the 50 mark... So helps would be appreciated... :-D
In the bottom left corner of the Export window, there is a drop-down list to change the sort order.
Hehe.. I feel dumb for not noticing that... Thanks :-D... :grinking:
