Please help me fix this template...
Hello,
I edited the default template that was loaded with Azn Movie Catalog. However.. I noticed that I must have done something wrong... Caused at the last entry (when exported to HTML).. There would be a gap in space...
Here... Check out this... You can tell.. at the last entry... There is a gap between the title and the comment.. Just look at the other two.. And you will see the difference...
This is what I have in my HTML export field
<html><head>
<style TYPE="text/css">
  text,body,p,div,span,th,td,ul,li { FONT-SIZE: 10pt; FONT-FAMILY: Trebuchet MS, Verdana, Arial, Helvetica, sans-serif; color: black; background: white; }
  HR { color: black; }
  A:link { COLOR: #003399; background: white; }
  A:visited { COLOR: #003399; background: white; }
  A:hover { COLOR: #CC0000; background: white; }
  A:active { COLOR: #CC0000; background: white; }
  td.blk { color: white; background: black; border: solid; border-color: black; }
  table.blk { color: white; background: black; border: solid; border-color: black; border-width: thin; }
  table.lgt { color: black; background: white; border: solid; border-width: thin; border-color: #F5F5F5; }
  td.lgt { color: black; background: white; border: solid; border-width: thin; border-color: #F5F5F5; }
  p.title { font-size: 18pt; font-weight: bold; }
</style></head><body>
<table class="blk" border="1" cellspacing="0" cellpadding="5"><tr>
<td class="blk" nowrap></td>
<td class="blk" nowrap>Vietnamese</td>
<td class="blk" nowrap>English</td>
</tr>$$ITEM_BEGIN<tr>
<td rowspan="2" class="lgt"><strong> $$ITEM_APPRECIATION<br>$$ITEM_PICTURE</strong></td>
<td class="lgt"><strong>$$ITEM_ORIGINALTITLE </strong></td>
<td class="lgt">$$ITEM_TRANSLATEDTITLE </td>
</tr><tr><td colspan="6" class="lgt">$$ITEM_DESCRIPTION </td></tr><tr><td colspan="7" class="blk"></td>
</tr>$$ITEM_END</table><p><strong>Total: $$TOTALMOVIES movies</strong></p></body></html>
[code]
I just delete and stuff without knowing what it does... But.. From looking at my sample site.. And this code.. Could anyone tell me how to fix the gap?
it is because there is less text and the cell contents is centred vertically.
you can add the attribute valign="top" (if I remember well) for the cell (<td>) that have to get their content at the top instead of vertical centre.
Thanks... I just found out there are a TONS of templates to pick from... So I end up picking something else... Since the one I had load up all the pics right away... Could be a bandwidh problem later down the road...
Thanks so much for the program and your help... I lubb it..
