Hello,
I'm trying to figure out how I can select the default font that is being used by the program... There are some non-English titles (Vietnamese for example) that has the symbols and signs, which doesn't show properly... So how can I fix this?
Nữ
That for example... Won't show properly in the program...
How can I select default font?
The fond used is "MS Sans Serif" I think.
It should display correctly if your computer has Vietnamese as default language settings.
To change the font of objets, open the langage file that you use (.lng file in "Languages" folder) and find lines like that :
here it assigns the hint displayed in the status bar where the mouse goes over the field
Add a line like this to also assign the font name :
MainWindow.FrmMovie.EMedia.Hint=|Media label, number or barcode
MainWindow.FrmMovie.EMedia.Font.Name=Comic Sans MS
MainWindow.FrmMovie.LSubtitles.Caption=Subtitles:
MainWindow.FrmMovie.EMedia.Hint=|Media label, number or barcodes
MainWindow.FrmMovie.EMedia.Font.Name=Tahoma
MainWindow.FrmMovie.EMediaType.Hint=|Media/support type
Not very good with coding stuff.. So dunno what I am doing wrong...
I found a work-around... What I did was use Microsoft Office to make a HTML file... With the proper unicode texts.. Save it as HTML.. Open it up.. And find the texts I want... Office would convert it to HTML code.. Copy paste that into the database.. Then when I ask it to export to HTML... It display it properly...
Yay
Yay
