Doubt about 4.0
d4rko
Doubt about 4.0
Post by d4rko »
First Post. Hi all :) .
I was thinking of starting to use this program but i dont know if with version 4 i will be able to import the collection created with 3.4.3. Will this be possible? Or should i wait for version 4?
Thanks in advance.
You should have read the two threads at the top of the list of this section :p
As written there, I am not sure that I will continue with version 4, maybe I will continue to make version 3 evolve (and become another version 4).
In any case it will be possible to import movies, since I have to transfer my own movie list to the new version ! And current version 3.4.3 can still open files of version 1.0 so why not continue like that ? ;)
d4rko
Post by d4rko »
Yep, i saw that maybe you are continuing version 3 instead of making a new 4. Thanks for the answer and for the program!.
Cheers.
