[ES] [SPA] Any script in Spanish??? Please help, thanks.
Laser
Post by Laser »
Hi, i used AMC some months ago without problem. Suddenly, Culturalia + IMDB script stopped from working :S :(
I tried to retrieve from internet any WORKING script in Spanish (i like much the one i used...) or a newer or remodeled version of my old one, but i couldn't find. I appreciate ur help, and my felicitations for such a good program.
Ciao.
The simple Culturalia script seems to still work.
it works, yes, but sometimes the script doesn't fill the LENGHT and IMDB RATE fields. Sorry ;) that was MY EXACT PROBLEM
Well, just let's hope that somebody can correct the other script.
I already have few scripts to correct, and if I use all my few free time to correct scripts the program will never progress :D
Culturalia+IMDB Script is working for me just now, what's the problem?
Sometimes there are problems with the web servers and get no result, but just try later.
Regards, folgui
Anonymous wrote: Regards, folgui
Seems that you forgot to login :D
