Culturalia+IMDB script Bug
Ant Movie Lover
Post by Ant Movie Lover »
Please note this bug in script Culturalia+IMDB :/
Sample 1:
Original Title:
Culturalia: Finding Nemo
Script: Finding nemo
Translated Title:
Culturalia: Buscando a Nemo
Script: Buscando a nemo
Sample 2:
Original Title:
Culturalia: Monsters, Inc.
Script: Inc. monsters
Translated Title:
Culturalia: Monstruos, SA
Script: Sa monstruos
It's not a bug, it's a feature :D
check the value of TitleMixedCase in the beginning of the script
Or simply delete this block if you want to keep the title as returned by the server :
  If TitleMixedCase then
     Result := AnsiMixedCase(Result, ' ')
     Result := AnsiLowerCase(Result);
     Result := AnsiUpFirstLetter(Result);
(maybe I should make that by default it keeps the title as returned by the server)
About the position of the "Inc" and "Sa", it's the other parts of code located in the function "TransformTitle".
If you want to disable all these changes, simply remplace the two occurences of "TransformTitle(tmp)" by "tmp"
Ant Movie Lover
Thanks!
antp wrote:If you want to disable all these changes, simply remplace the two occurences of "TransformTitle(tmp)" by "tmp"
Thanks!
:grinking: :grinking: :grinking: :grinking:
