Images are stored now out of the database file
Amon
Post by Amon »
I have upgrade from 3.4.2 to 3.4.3 and I can not make the program to store the pics in the database file, it stores them like independent jpg files. Any clue to solve this?
Thanks.
That happens when you add pic through script or using the icons of the main window ?
Amon
Post by Amon »
Hi:
When adding via script. I use this metod always, after and before the upgrade, and I have never had this problem till now.
(Thanks very much for your software).
Amon
Post by Amon »
FWIW: I use the script icon in the main window, what is linked to the "Culturalia+IMDB" script.
in the script (using the "Editor" tab), modify the line "ExternalPictures = True;"
Amon
Post by Amon »
Done!
Thanks.
Iñigo.
