It's possible, in this script, to take the official site instead of the page's url?
Forse in italiano è meglio..
Nello script filmup viene scaricato l'url della pagina della scheda del film, invece mi sembra più utile scaricare l'indirizzo della pagina ufficiale del film.
Come posso fare??
Grazie e ciao!!
FilmUp.com Script
Ok.
Below are modified script for FilmUp:
Change the added AltURL constant to True (line 29 of script) if you want to get the film web site link instead of FilmUp page link (FilmUp link is already taken if film web site not found).
Regards
Pivello
Regards
Pivello
// GETINFO SCRIPTING
// FilmUP (IT) import
* Movie importation script for: *
* FilmUP (IT), http://www.filmup.com *
+ Original: L. Francisco *
* Modified: Pivello: query URL changed *
* Modified: Zandal: sistenato puntamento a *
* COMMENTS *
* Modified: Pivello: Film site URL selectable *
* instead of FilmUp page URL *
* For use with Ant Movie Catalog 3.4.1 *
* www.ant.be.tf/moviecatalog *
* The source code of the script can be used in *
* another program only if full credits to *
* script author and a link to Ant Movie Catalog *
* website are given in the About box or in *
* the documentation of the program *
program FilmUP;
AltURL = False; // - Set to true if film web site needed for FieldURL (FilmUp
// page URL is already taken if film web site not found)
// - Set to false for FilmUp page URL
TheMovieAddress: string;
result := -1;
if StartAt < 0 then
StartAt := 0;
result := i;
LineNr: integer;
BeginPos: integer;
LineNr := FindLine('<title>FilmUP - Cerca: ', Page, 0);
if LineNr = -1 then
AnalyzeMoviePage(Page);
AddMoviesTitles(Page);
if TheMovieAddress='' then
if PickTreeExec(Address) then AnalyzePage(Address);
NomeHtml: string;
LineNr,PrevLineNr: Integer;
BeginPos, EndPos: Integer;
Field: integer;
LineNr := FindLine('<font face="arial, helvetica" size="3"><b>', Page, 0);
if LineNr > -1 then
//Translated Title
HTMLRemoveTags(Line);
//Look for next info
LineNr := LineNr + 1;
until Line<>'';
//Look for type of line
if Line = 'Titolo originale: ' then
Field := fieldOriginalTitle
else if Line = 'Regia: ' then
Field := fieldDirector
else if Line = 'Produzione: ' then
Field := fieldProducer
else if Line = 'Nazione: ' then
Field := fieldCountry
else if Line = 'Genere: ' then
Field := fieldCategory
else if Line = 'Anno: ' then
Field := fieldYear
else if Line = 'Durata: ' then
Field := fieldLength //Special case: get number only
else if Line = 'Sito ufficiale: ' then
Field := fieldURL
else if Line = 'Cast: ' then
Field := fieldActors
else if Line = 'Trama:' then
Field := fieldDescription
Field := 0;
// I have to add this test, for sometimes the description
// is on the same line as the tag 'Trama'
if (copy(Line,1,6)='Trama:') and (length(Line)>6) then
Field := fieldDescription;
Delete(Line,1,6);
HTMLDecode(Line);
//Get values
HTMLDecode(Line);
//Special case: Length
if Field = fieldLength then Line := copy(Line,1,length(Line)-1);
//Alternative URL case
if (field = fieldURL) and AltURL then
if Length(Line) = 0 then // if WEB url missing...
Line := GetField(fieldURL) // ...restore FilmUp URL
Line := 'http://'+Line;
if Field<>0 then SetField(Field,Line);
until Field=fieldDescription;
PrevLineNr := LineNr;
//Comments
LineNr := FindLine('">Recensione</a>', Page, PrevLineNr);
if LineNr > -1 then
if Pos('DVD', Line) <> 0 then Delete(Line,1,pos('DVD',Line));
if Pos('Scheda', Line) <> 0 then Delete(Line,1,pos('Scheda',Line));
Delete(Line,1,pos('<a href="',Line)+8);
NomeHtml :=Copy(Line,1,pos('"',Line)-1);
if (copy(NomeHtml,1,1)<>'/') then
NomeHtml := '/' + NomeHtml;
GetComments('http://www.filmup.com'+NomeHtml);
//Rating
LineNr := FindLine('">Opinioni</a>', Page, PrevLineNr);
if LineNr > -1 then
Delete(Line,1,pos('Recensione',Line));
Line := GetLineFromOtherPage(Copy(Line,1,pos('"',Line)-1),'</b> - <img src="/img/star/');
if Line <> '' then
Line := Copy(Line,1,pos('</b> - <img src="/img/star/',Line)-1);
if pos('.',Line)>0 then Line := Copy(Line,1,pos('.',Line)-1);
SetField(fieldRating,Line);
//Picture
LineNr := FindLine('<a href="posters/locp/', Page, PrevLineNr);
if LineNr = -1 then
LineNr := FindLine('<img src="locand/', Page, PrevLineNr);
if LineNr > -1 then
Delete(Line,1,pos('<img src="locand/', Line)+9);
GetPicture('http://www.filmup.com/'+Copy(Line,1,pos('"',Line)-1), False);
Delete(Line,1,pos('<a href="posters/locp/',Line)+8);
Line := GetLineFromOtherPage('http://www.filmup.com/'+Copy(Line,1,pos('"',Line)-1),'<img src="../loc/500/');
if Line <> '' then
Delete(Line,1,pos('<img src="../',Line)+12);
GetPicture('http://www.filmup.com/posters/'+Copy(Line,1,pos('"',Line)-1), False);
DisplayResults;
function GetLineFromOtherPage(address: string; hint: string): string;
LineNr: integer;
LineNr := FindLine(hint, Page, 0);
if LineNr > -1 then result := Page.GetString(LineNr);
procedure GetComments(address: string);
BeginLine: integer;
EndLine: integer;
i: integer;
Line, Comments: string;
BeginLine := FindLine('RECENSIONI', Page, 0);
BeginLine := FindLine('<font face="arial,helvetica" size="2"><b>', Page, BeginLine);
EndLine := FindLine('<a href="opinioni.htm">Scrivi la tua recensione!</a></font><br><br>', Page, BeginLine);
for i:= BeginLine+1 to EndLine-1 do
Line := Page.GetString(i);
Line := StringReplace(Line, '<br>', #13#10);
Line := StringReplace(Line, #13#10#32, #13#10);
HTMLDecode(Line);
Comments := Comments + Line;
LineNr := 0;
LineNr := FindLine('FilmUP - Scheda:',Page,LineNr);
while LineNr > -1 do
BeginPos := pos('<a href="',Line)+9;
EndPos := pos('" TARGET="_blank"><b>FilmUP - Scheda: ',Line);
MovieAddress := copy(Line,BeginPos,EndPos-BeginPos);
Delete(Line,1,EndPos);
BeginPos := pos('Scheda: ',Line)+8;
EndPos := pos('</a>',Line);
MovieTitle := copy(Line,BeginPos,EndPos-BeginPos);
HTMLRemoveTags(MovieTitle);
HTMLDecode(Movietitle);
LineNr := FindLine('FilmUP - Scheda:',Page,LineNr+1);
if TheMovieAddress='*' then
TheMovieAddress := MovieAddress
TheMovieAddress := '';
LineNr := FindLine('Successivo',Page,LineNr);
BeginPos := pos('HREF',Line);
if BeginPos>0 then
Delete(Line,1,BeginPos + 5);
EndPos := pos('"',Line);
MovieAddress := copy(Line,1,EndPos-1);
PickTreeMoreLink('http://www.filmup.com'+MovieAddress);
// Questo è il main dello script
if CheckVersion(3,4,1) then
TheMovieAddress := '*';
if Input('FilmUP Import', 'Digita il titolo del film:', MovieName) then
AnalyzePage('http://www.filmup.com/cgi-bin/search.cgi?q='+UrlEncode(MovieName)+'&ul=%25%2Fsc_%25');
ShowMessage('Questo script richiede una versione più nuova di Ant Movie Catalog (almeno la versione 3.4.1)');
