Rating system
fjeronimo
Rating system
Post by fjeronimo »
First of all, congratulations on such a fine program. I have one question though. Is it in any way possible to change the rating system for the movies. It is currently out of 10, but I for instance use a different system out of 8.
I would also like to keep the imdb rating on the movies, besides my own rating.
I could use the comments section to write the rating manually, but since I noticed that most dropdowns have customizable values, why not the rating one?
Thanks in advance.
It is not possible to change the ratings for the moment. I do not know it it will be possible in the future, but there will probably be 2 ratings for people that want, like you, their rating and public's rating.
The rating being a numeric value, that's why it does not havw a customizable value list.
Thanks for the quick answer. My next related question is if there is any modified version of the scripts that automatically fills the comments section with the imdb rating (with decimals)?
I do not think
AirH
Post by AirH »
In version 4 is it possible to make a rating for him and a rating for his girlfriend for exemple?
Merci pour ce super logiciel
And a rating for a friend, another one for the dog, etc. ? :D
There will maybe be two ratings fields as I said, so you'll use them for what you want.
AirH
Post by AirH »
Thanks for your reponse.
2 rating is not possible in actual version?
No.
You'll have to wait a future version, and I will only add new fields in version 4.
But you can use one of the currently unused fields for that, until a new field is added.
TekmanRO
Post by TekmanRO »
AirH wrote:2 rating is not possible in actual version?
You could use user defined fields to define any number of ratings that you want (that will keep you, your girlfriend, and the dog happy :p)
Like here.
