Help with html exporting?
deerNheadlights
Post by deerNheadlights »
Is it possible to export your list so that the html version includes director/running time/cast etc.? Is there something I'm missing? I'm getting an abbreviated listing with title/description and a couple other things. I figured it was possible to export all of the information to html? Sorry if this is a lame question but I love this program and I want to get the most out of it.
You have to modify the template for that.
If you do not know HTML at all, you can say which columns you want to add or remove, and I'll send you a modified file...
