export list to excel
taz506man
Post by taz506man »
I recently downloaded your progam and was seeing what the info would look like in excel your main page says you can use the program. when i open the list in excell it puts all the info into one field, how can i move the info to excel so it is separated into the different columns.
original title media type year
in the cut dvd 2003
intolerable cruelty dvd 2003
swimming pool dvd 2003
Export to other formats: HTML (based on a template that you can modify or create yourself), SQL commands (to re-import data in a DBMS such as MySQL), CSV (text files, can be used as tables with Microsft Excel for example), Origons.com
help if you can please
you have to change the value of the "separator" and "replace separator by" fields.
By default it is ";" and "," I think. Just try to exchange them. Depending of Windows configuration Excel wants ";" or "," to separate fields.
