Script for AFdigitale.it
P2
Post by P2 »
I have written a script for AFdigitale.it.
Regards
Pivello
// GETINFO SCRIPTING
// AFdigitale.it - by Pivello
*  AFdigitale.it, http://www.AFdigitale.it        *
* (c) 2004 Pivello                                *
*  14.04.2004 First Public Release                *
*  For use with Ant Movie Catalog 3.4.1           *
program AFdigitale;
 UrlBase = 'http://www.afdigitale.it';
 QueryBase = UrlBase + '/edisport/afdigitale/dvd.nsf/DVDS?SearchView&Query=';
 MovieUrl, MovieName, OriginalStr, TranslatedStr, PageStr:  string;
// PAGE PACKING (remove extra spaces, tabs & CR)
// IN:  page Url     (string)
// OUT: compact page (string)
  Temp: string;
  PackedPage: string;
  CharPos: Integer;
  n: Integer;
  Page.Text := GetPage(Url);
  for n:=0 to Page.Count-1 do
   if CharPos = 0 then
   if CharPos <> 0 then
     Temp := copy(PackedPage, 1, CharPos -1);
  result := PackedPage;
// GET FIELD VALUES FROM PACKED PAGE
// IN:  Start marker     (String)
//      End marker       (string)
//      Cut Start Marker (bool)
//      Cut End Marker   (bool)
// OUT: value            (string)
function GetValue(StartMarker, EndMarker: string; CutStartMarker, CutEndMarker: boolean): string;
 StartPos: integer;
 EndPos: integer;
 Value: string;
 Value := '';
 StartPos := pos(StartMarker, PageStr);
 if (StartPos > 0) then
  Delete(PageStr, 1, StartPos-1);
 EndPos := pos(EndMarker, PageStr);
 if ((StartPos > 0)and(EndPos > 0)) then
   if CutStartMarker then
    StartPos := StartPos + length(StartMarker);
   if not CutEndMarker then
    EndPos := EndPos + length(EndMarker);
   Value := copy(PageStr, StartPos, EndPos-Startpos);
   Delete(PageStr, 1, EndPos);
 result := Value;
// ANALYZE MOVIE DATA PAGE
// IN:  none
// OUT: set Ant fields
procedure AnalyzeMoviePage;
 TempStr: string;
 // Get packed title main page
 // image
 GetPicture(UrlBase + getValue('ROWSPAN=2><IMG SRC="','" WIDTH=',true,true), False);
 // Translated Title field
 SetField(fieldTranslatedTitle, getValue('COLOR="000080" FACE="Verdana">','</FONT></B><BR>',true,true));
 // Original Title field
 SetField(fieldOriginalTitle, getValue('COLOR="000080" FACE="Verdana">','</FONT></TD>',true,true));
 if((GetField(fieldOriginalTitle)='id') or (GetField(fieldOriginalTitle)=''))then
 // Category Field
 SetField(fieldCategory, getValue('</B><B><FONT SIZE=1 COLOR="000080" FACE="Verdana">','</FONT></B><BR>',true,true));
 // Director Field
 SetField(fieldDirector, getValue('<B><FONT SIZE=1 COLOR="000080" FACE="Verdana">','</FONT></B><BR>',true,true));
 // Actors Field
 SetField(fieldActors, getValue('<B><FONT SIZE=1 COLOR="000080" FACE="Verdana">','</FONT></B><BR>',true,true));
 // YearField
  SetField(fieldYear, getValue('<B><FONT SIZE=1 COLOR="000080" FACE="Verdana">','</FONT></B><BR>',true,true));
 // Producer Field
 Delete (PageStr,1,pos('Distribuito da:',PageStr));
 SetField(fieldProducer, getValue('<B><FONT SIZE=1 COLOR="000080" FACE="Verdana">','</FONT></B>',true,true));
 // Duration field
 Delete (PageStr,1,pos('FACE="Verdana">Durata:</FONT>',PageStr));
 SetField(fieldLength, getValue('COLOR="ffffff" FACE="Verdana">','</FONT></B><B>',true,true));
 // Size Field
 Delete (PageStr,1,pos('FACE="Verdana">Supporto: </FONT>',PageStr));
 SetField(fieldSize, getValue('FACE="Verdana">','</FONT></B><BR>',true,true));
 // Description Field
 Delete (PageStr,1,pos('Qualità artistica:',PageStr));
 TempStr := getValue('<FONT SIZE=2 FACE="Verdana">','</FONT><BR>',true,true);
 HTMLDecode(TempStr);
 SetField(fieldDescription, TempStr);
 // Comments Field
 Delete (PageStr,1,pos('Qualità dell''edizione:',PageStr));
 SetField(fieldComments, TempStr);
 // Movie URL field
 SetField(fieldURL, MovieUrl);
 // Display search result
 DisplayResults;
// IN:  OneFilm flag (bool)
// OUT: one page ID  (string)
  TempUrl: string;
  TempTitle: string;
  StartPos: integer;
  EndPos: integer;
 result := '';
 StartPos := pos('<A HREF="', PageStr);
 Delete(PageStr, 1, StartPos - 1);
 if OneFilm then
   EndPos := pos('"><div', PageStr);
   if StartPos > 0 then
     TempUrl := copy(PageStr, StartPos + 9, EndPos-Startpos - 9);
     result := UrlBase + TempUrl;
    EndPos := pos('?OpenDocument', PageStr);
      TempUrl := copy(PageStr, StartPos + 9, EndPos-Startpos + 4);
      Delete(PageStr, 1, EndPos + 1);
      StartPos := pos('''">', PageStr);
      EndPos := pos('</div>', PageStr);
      TempTitle := copy(PageStr, StartPos + 3, EndPos-Startpos - 3);
      PickTreeAdd(TempTitle, UrlBase + TempUrl);
   until(StartPos = 0);
// IN:  none
// OUT: none
procedure AnalyzeSearchPage;
 if pos('Nessun elemento trovato', PageStr) > 0 then
 else if pos('Si è verificato un errore',PageStr) > 0 then
   ShowMessage('Server not available, try later / Server non disponibile, prova più tardi')
   if pos('1 elemento trovato', PageStr) > 0 then
    MovieUrl := PopulatePickTree(true)  // One title found
     PopulatePickTree(false);           // More titles found..
   AnalyzeMoviePage;
// MAIN:
// IN:  none
// OUT: none
 if CheckVersion(3,4,1) then
   if (TranslatedStr <> '') then MovieName := TranslatedStr else MovieName := OriginalStr;
   if (Input('AFdigitale.it - By Pivello', 'Enter the title of the movie / Inserire titolo del film:', MovieName)) then
     MovieUrl := QueryBase + UrlEncode(MovieName);
     AnalyzeSearchPage;
  ShowMessage('This script requires a newer version of Ant Movie Catalog (at least the version 3.4.1)');
nice ;)
TanATos
Post by TanATos »
Thanks a lot !!!
:grinking:
Is possible to get more information ???
For example:
Audio Format, Language,Subtitles,....
:p
