Missing number
coolisio
Missing number
Post by coolisio »
As you can see on the picture i'm missing the numer 26. The problem is that i allready printed the following numbers (27;28;29;etc) with the numbers on the covers. Is there any possible way to insert this numer between 25 and 27. It would be great of someone can help me. Thanks
With Movie -> Change number you can change the number of a movie
When adding a new movie you can also select the number, except if you said in the options that you do not want to.
