New script for 35mm.it
P2
Post by P2 »
Hello, this is my first post. :)
The 35mm.it script is no longer working... because the site has moved form old .XTML to new .JSP pages.
I have rewritten the script for 35mm.it:
// GETINFO SCRIPTING
// 35mm.it - by Pivello
*  35mm.it, http://www.35mm.it                    *
* (c) 2004 Pivello                                *
*  12.04.2004 New script for XTML->JSP migration  *
*  14.04.2004 Added test for Apache Server down   *
*             Removed <br> from comments field    *
*  15.04.2004 Code optimization                   *
*             Get film image if cover not found   *
*  For use with Ant Movie Catalog 3.4.1           *
program New35mm;
  UrlBase = 'http://www.35mm.it';
  QueryBase = UrlBase + '/film/ricerca/bottom/ricercaschedafilm.jsp?titolo=';
  QueryFilm = UrlBase + '/film/scheda/top/scheda.jsp?idFilm=';
  QueryCast = UrlBase + '/film/scheda/bottom/cast.jsp?idFilm=';
  QueryCover = UrlBase + '/film/scheda/bottom/homevideo.jsp?idFilm=';
  QueryMovie = UrlBase + '/film/scheda/frameset/scheda.jsp?idFilm=';
  QueryCmnts = UrlBase + '/film/scheda/bottom/recensioni.jsp?idFilm=';
  MovieUrl, CastUrl, FilmUrl, CoverUrl, CmntsUrl: string;
  MovieName, OriginalStr, TranslatedStr, PageStr:  string;
// PAGE PACKING (remove extra spaces, tabs & CR)
// IN:  page Url     (string)
// OUT: compact page (string)
  Temp: string;
  PackedPage: string;
  CharPos: Integer;
  n: Integer;
  Page.Text := GetPage(Url);
  for n:=0 to Page.Count-1 do
   if CharPos = 0 then
   if CharPos <> 0 then
     Temp := copy(PackedPage, 1, CharPos -1);
  result := PackedPage;
// GET FIELD VALUES FROM PACKED PAGE
// IN:  Start marker     (String)
//      End marker       (string)
//      Cut Start Marker (bool)
//      Cut End Marker   (bool)
// OUT: value            (string)
function GetValue(StartMarker, EndMarker: string; CutStartMarker, CutEndMarker: boolean): string;
  StartPos: integer;
  EndPos: integer;
  Value: string;
  Value := '';
  StartPos := pos(StartMarker, PageStr);
  if (StartPos > 0) then
   Delete(PageStr, 1, StartPos-1);
  EndPos := pos(EndMarker, PageStr);
  if ((StartPos > 0)and(EndPos > 0)) then
    if CutStartMarker then
     StartPos := StartPos + length(StartMarker);
    if not CutEndMarker then
     EndPos := EndPos + length(EndMarker);
    Value := copy(PageStr, StartPos, EndPos-Startpos);
    Delete(PageStr, 1, EndPos);
  result := Value;
// ANALYZE MOVIE DATA PAGE
// IN:  none
// OUT: set Ant fields
procedure AnalyzeMoviePage;
  i, h, m: integer;
  Duration, Description, Cast, TempStr, TempImg, hh, mm: string;
  // Get packed title main page
  PageStr := RemoveExtraChars(FilmUrl);
  // Get film image (used if cover not found)
  TempImg := getValue('/immagini/film/','" width="150" height="150"',false,true);
  // Translated Title field
  SetField(fieldTranslatedTitle, getValue('<!-- titolo --> <b>','</b>',true,true));
  // Original Title field
  SetField(fieldOriginalTitle, getValue('<!-- titolo originale --> <b>','</b>',true,true));
  if(GetField(fieldOriginalTitle)='')then
  // Country field
  SetField(fieldCountry, getValue('<!-- nazionalità --> ','<br>',true,true));
  // Duration field
  TempStr := getValue('<!--durata del film --> ','<br>',true,true);
  Duration := '';
  if (length(TempStr) > 0) then
    i := Pos('e', TempStr);
    hh := copy(TempStr, 1, i - 3);
    mm := copy(TempStr, i + 2, Length(TempStr) - i - 2);
    h := StrToInt(hh, 2);
    m := StrToInt(mm, 2);
    Duration := IntToStr(h * 60 + m);
  SetField(fieldLength, Duration);
  // Category Field
  SetField(fieldCategory, getValue('<!-- genere --> <b>','</b>',true,true));
  // Director Field
  SetField(fieldDirector, getValue('target="_top">','</a>',true,true));
  // YearField
  SetField(fieldYear, getValue('<!-- anno --> Anno: ','<br>',true,true));
  // Producer Field
  SetField(fieldProducer, getValue('target=''_TOP''>','</a>',true,true));
  // Description Field
  Description := '';
   TempStr := getValue('<span class="trecinque_dat">','<br>',true,true);
   Description := Description + TempStr+ ' ';
  until(TempStr='');
  SetField(fieldDescription, Description);
  // Actors Field
  PageStr := RemoveExtraChars(CastUrl); // Get packed Cast page
  PageStr := Copy(PageStr,1,pos('<!-- end list cast -->',PageStr));
  Cast := '';
   TempStr := Trim(getValue('target="_top">','</a>',true,true));
   if ((Cast<>'') and (TempStr<>'')) then
    Cast := Cast + ', ';
   Cast := Cast + TempStr;
  until((TempStr='')or(Length(TempStr)>20));
  if Cast = '' then
   Delete (PageStr,1,pos('<!-- produzione -->',PageStr));
   Cast := Trim(getValue('</span><br>','<br> </td>',true,true));
  SetField(fieldActors, Cast);
  // image
  PageStr := RemoveExtraChars(CoverUrl); // Get packed cover page
  TempStr := getValue('/immagini/','" align="',false,true);
  if TempStr = '' then
   TempStr := TempImg;
  GetPicture(UrlBase + TempStr, False);
  // Size Field
  SetField(fieldSize, getValue('Supporto: <span class="trecinque_dat_scuro_nobold">','</span>',true,true));
  // Comments Field
  PageStr := RemoveExtraChars(CmntsUrl); // Get packed comments page
  Delete (PageStr,1,pos('<!-- recensioni redazione esplose -->',PageStr));
  TempStr := getValue('<td class="trecinque_dat_scuro_nobold">','<br> <br>',true,true);
  HTMLRemoveTags(TempStr);
  SetField(fieldComments, TempStr);
  // Movie URL field
  SetField(fieldURL, MovieUrl);
  // Display search result
  DisplayResults;
// IN:  OneFilm flag (bool)
// OUT: one page ID  (string)
  TempIdFilm: string;
  TempTitle: string;
  StartPos: integer;
  EndPos: integer;
  if OneFilm then
    StartPos := pos('/film/scheda.jsp?idFilm=', PageStr);
    EndPos := pos(''' target=''_top''', PageStr);
    if StartPos > 0 then
      TempIdFilm := copy(PageStr, StartPos + 24, EndPos-Startpos-24);
      result := QueryMovie + TempIdFilm;
     StartPos := pos('<a href="/film/scheda.jsp?idFilm=', PageStr);
     EndPos := pos('" target="_top"', PageStr);
       TempIdFilm := copy(PageStr, StartPos + 33, EndPos-Startpos-33);
       StartPos := pos('">', PageStr);
       EndPos := pos('</a>', PageStr);
       TempTitle := copy(PageStr, StartPos + 3, EndPos-Startpos-4);
       PickTreeAdd(TempTitle, QueryMovie + TempIdFilm);
    until(StartPos = 0);
    result := '';
// OUT: none
procedure AnalyzeSearchPage(Url: string);
  FilmId: string;
  PageStr := RemoveExtraChars(Url);
  if pos('Nessun film trovato.', PageStr) > 0 then
  else if pos('Si è verificato un errore',PageStr) > 0 then
    ShowMessage('Server not available, try later / Server non disponibile, prova più tardi')
    if pos('Risultato della ricerca:', PageStr) = 0 then
     MovieUrl := PopulatePickTree(true)  // One title found
      PopulatePickTree(false);           // More titles found..
    FilmId := Copy(MovieUrl,59,20);      // get film id from movie url
    FilmUrl := QueryFilm + FilmId;
    CastUrl := QueryCast + FilmId;
    CoverUrl := QueryCover + FilmId;
    CmntsUrl := QueryCmnts + FilmId;
    AnalyzeMoviePage;
// MAIN:
// IN:  none
// OUT: none
  if CheckVersion(3,4,1) then
    if (TranslatedStr <> '') then MovieName := TranslatedStr else MovieName := OriginalStr;
    if (Input('35mm.it - By Pivello', 'Enter the title of the movie / Inserire titolo del film:', MovieName)) then
      MovieUrl := QueryBase + UrlEncode(MovieName);
      AnalyzeSearchPage(MovieUrl);
   ShowMessage('This script requires a newer version of Ant Movie Catalog (at least the version 3.4.1)');
Regards
Pivello
P.S. sorry for my english ;)
Thanks ;)
P2
Some updates...
Post by P2 »
Two updates for my 35mm script:
- Added test for 35mm Apache Server down (or not available, like tonight)
- Removed extra '<br>' from Comments field
Regards
Pivello
you should edit your first post to put the update instead of putting it in your second post :/
P2
Post by P2 »
antp wrote:you should edit your first post to put the update instead of putting it in your second post :/
Sorry...
No problem.
It's better now ;)
P2
Post by P2 »
Another small update:
Get image from film page if cover not found.
Regards
Pivello
Ciao Pivello, ottimo lavoro, anche se però c'è un problema...quando và a prendere la trama prende solo il pezzo iniziale e non tutta.
Se hai notato in alcuni film c'è il tasto continua dove si può leggere tutta la trama, si riesce a fargliela prendere tutta e non solo il pezzo iniziale?
Hello Pivello, optimal job, even if but are a problem... when to
take the weft take the piece alone begin them and not all. If you have
noticed in some films is the continuous key where can be read to all
the weft, it is succeeded to make it to take it all and not only the
piece begins them?
Sorry for my english
:??: :hum: :( :badidea:
:ha:
