new MovieMeter.nl script
JanC
Post by JanC »
The people at MovieMeter.nl have added support for GET requests (maybe because they wanted to make a Mycroft search plugin for Mozilla--that's how I found this alternative search method for their site).
So, I made a new MovieMeter script tonight. :)
You can find it here:
http://users.telenet.be/janc/MovieMeter.zip
I would like some people to test this script before Antoine adds it to a new AMC release. I have tested it a bit, but I'm not sure I have found all bugs...
(Add your success or failure reports to this thread please. ;) )
Hi, thanks for the info, and of course thanks for making the new script ! ;)
PS: you probably made an error in the URL : "not found"
JanC
Post by JanC »
:hum: Oops.
That's what happens when you stay up all night... :/
The link should work now.
Thanx a lot !
I was waiting for a new dutch script for a long time now...
No I have to do all the movies over again, your fault ! :)
JanC
Post by JanC »
Anonymous wrote:No I have to do all the movies over again, your fault !
Well, that sounds like a good test for the script... :wink:
I have try to test it, but only message what I get is: There is no result for "movie".
I am using 3.4.3 version.
What can be wrong?
One more question:
Is it possible to make script which can download information for more than one film at the same time. For example I want to get information about 100 films with only one push at the button , instead of 100?
JanC
Post by JanC »
Anonymous wrote:I have try to test it, but only message what I get is: There is no result for "movie".
What movie did you search for (is it on that site?).
BTW: you didn't forget to unzip the zipfile above and copy the .ifs file inside it in the amc\Scripts directory? ;)
Anonymous wrote:Is it possible to make script which can download information for more than one film at the same time. For example I want to get information about 100 films with only one push at the button , instead of 100?
Select those 100 movies & see: Tools --> Scripting...
It doesn't matter waht movie I am searching for ( Never been kissed, Shallow Hal etc.) I get every time pop up window that: There is no result for "movie".
Thanks for hint. It works but with every movie there is answer: there is no result for "movie".
JanC
Post by JanC »
Anonymous wrote:It doesn't matter waht movie I am searching for ( Never been kissed, Shallow Hal etc.) I get every time pop up window that: There is no result for "movie".
I tested with "Never been kissed" and it works for me.
Do other scripts (for other sites) work without problems?
Also, if you look at the script code using the "Editor" tab in the script dialog, it should say the following at line 8:
 *  Now works with the new site !!                 *
Otherwise you're using an old version...
JanC
Post by JanC »
Problem solved (his firewall was blocking Ant Movie Catalog ;) ).
Tested with lots of movies now, so it seems like the the script is good enough to be included in the next version of AMC.
ok ;)
Abdul
Post by Abdul »
Thanks a million
Works like a charm
