imdb?
stromboli2
imdb?
Post by stromboli2 »
a direct connection to the imdb bases on the title and /or director will be great and the ability to update the content of the catalog with the data of the imdb.
it is not possible to have a direct connection to IMDB
all what can be done currently is what is used by most of the users : the scripts that analyze and extract info from IMDB website
