HOW TO MAKE IMDB SCRIPT TO MARK ONLY PICTURE box TO IMPORT?
Hi, i want to donwload just the covers
Now i have to deselect the boxes for title, length, cast...etc
Can anyone tell me please what to change in the script so that only
the picture box is selected?
thanks
lacenaire2
procedure to do that
Post by lacenaire2 »
*** FIRST MAKE A BACKUP OF THE SCRIPT YOU ARE GOING TO MODIFY
For instance if you want not to take :
// Original Title & Year
then just delete this line in the script:
and do the same with the other fields you don't want to get
you can also put a "//" in front of the line that you want to delete. So you can get it back easily by removing the "//"
But for importing picture only, IMDB is not the best (especially if you want the big picture, since it comes from Amazon).
