print
niggger
print
Post by niggger »
I'm tryingto print some, but I can't print with the full size. I was trying to resize the scripts, but I don't know how.
What do you mean by "print with the full size" ?
Which template (not script) do you use ?
niggger
print
Post by niggger »
OK,
I'm using "List1", for printing. But when I print the list, It doesn't appears in the full size.
Some of the begining and the final text, includding de square lines, doesn't appears, and I can't read it completly.
So I was trying to resize the margins, but I could't...
I guess that's because your printer needs larger margins than others.
Did you try to reduce the size of the text blocs of the templates ?
niggger
print
Post by niggger »
Yes, but I can't find the way to do that....
I had been looking for that instruction, but I could'y find it...
