cecco
Post
by cecco » 2004-04-04 13:28:31
The measures displayed in the template editor are not the real measures of the print.
There is a difference between lenght and width, the distortion is not homogenous.
Is only a my problem?
thanks
cecco
Post
by cecco » 2004-04-04 13:37:13
Sorry, the post is for Ant Movie Catalog.
Posts: 9811 Joined: 2002-05-30 10:13:07
Post
by antp » 2004-04-04 15:01:20
Ok, I'll move your post to the right section then.
Is the page size specified in the page properties the same than the one used in your printer ?
cecco
Post
by cecco » 2004-04-05 14:59:04
yes, i use A4 papier.
to print a square 120x120mm, the dimension must be 126,70x123,90mm.
Post
by antp » 2004-04-05 17:09:42
Yes, because a friend that made a CD template said me that it was working fine.
And I guess that the people that made existing CD & DVD templates could get it working correctly since they did not said anything about a measure problem.
cecco
Posts: 4 Joined: 2004-04-05 15:02:25
Post
by cecco » 2004-04-06 09:17:40
well...
what can i do for working right?
Post
by antp » 2004-04-06 11:45:36
I don't know
cecco
Post
by cecco » 2004-04-06 12:02:24
can be a bug of the program or a wrong setup of the template?
Post
by antp » 2004-04-06 12:44:02
I guess it is a problem between FreeReport (what I use for the printing) and your printer driver.
