How can I add like 400 files from a directory ?
I would like to add >400 files i have on disk.
it's too much job to ALT-INS , then drag and drop them...
I tried to dir *.divx /b >temp.csv , but no divx info is extracted then...
what's the corect way to do it ?
Thanks - great software.
For the moment there is not easy way to do that, sorry :(
I should add an option for that...
tanel
Post by tanel »
viewtopic.php?t=229&sid=5a7cf5ca3dd36de ... b7eb33d789
That's how I did it, worked like a charm :D
Thanks antp
Your welcome ;)
I did not think to this solution when I answered here :/ (it was more than two weeks before the other)
