IMDB (pic) script prob with "Lilo & Stitch"
Am using AMC 2.4.3 and having been using program for years and this is the first problem I've ever run into.
When using the IMDB (pic) script with "Lilo & Stitch" it returns a list of totally unrelated movies with the best matches all called "Q". The movie does exist in IMDB at http://www.imdb.com/title/tt0275847/
Oh... forgot to mention that it does return correct movie when you reduce the search to just "Lilo" so I'm assuming it is not handling the & character correctly?
That's funny... but I do not know why this happens :D
