Default scripts to use...
Sashyk
Post by Sashyk »
Is it possible to set some scripts "default" to use?
But... I think it may be it would be useful to have the list of "favourite" scripts (3 favorites would be enough)..
What do you mean by default ? There is an option to remember the last script used.
And you can delete the scripts that you do not use, from Windows' Explorer.
Sashyk
Post by Sashyk »
antp wrote:What do you mean by default ? There is an option to remember the last script used.
Sorry, I was using old version and haven't notice this option.. Thanks for paying attention.. :(
