Version 3.4.0
What's new in Ant Movie Catalog, beta versions, etc...
Version 3.4.0
The version 3.4.0 is available !
You can download it from the following link :
ftp://ftp2.antp.be/antp/software/amc_install.exe
Some translations are not yet updated. They will be ready within few days.
Ready translations are: French, Spanish, Hungarian, Bulgarian, Danish.
So if you use another translated version some parts will remain in english.
Main new features of this version:
  • * Printing, using customizable templates.
    * When in Grid mode, columns width and order are saved.
    * Threaded download : should resolve some problems with Main Window/Script Window when downloading a web page.
    * Import video and audio bitrate from AVI files.
    * Functions to modify the case (upper case, lower case, mixed case...) in the Scripting tool.
Version 3.4 has been updated.
Changes are minor :
- Updated IMDB scripts since IMDB.com changed their site (unfortunately the "large pic" version of the script is no more available).
- Updated Cinéstore script, for the same reason, thanks to its author ;)
- Added a script for the Hungarian site www.port.hu
- Updated some languages (translations) files.
- Corrected a bug in the Print window on 800x600 monitor (bottom of the window were not visible).
If you do not want to download the full package again, you can update scripts and/or translations from here:
ftp://ftp2.antp.be/antp/software/amc_scripts.zip
ftp://ftp2.antp.be/antp/software/amc_lang.zip
Updated again:
- Corrected a bug in the IMDB script
- Corrected a bug in the SQL export
I had to change something in the program itself for the IMDB script so if you want to use the script that downloads pictures you will have to download the whole program again and not just the script, sorry :/
A small update :
- Added a Finnish translation
- Updated some scripts
- Updated Import DLL so it can import Divx Manager 1.0 databases
Again a small update :
- updated Allociné & IMDB script (Allociné was updated two days ago, so if you already downloaded this update separately you do not have to update it again)
- updated Korean translation
Small update:
- Corrected a bug in the XML (sometimes the "#" were replaced by a "39#")
- Added a "Sleep" function in the scripting to avoid server errors in mass-import.
- Added/updated few scripts & templates.
I updated again the program, to include updates of various scripts and templates.
I also rewrote the script for dvdzone2.com since the site has changed.
Now it gets all information in English, since it is the default langage of the site.
I think that I need to manage cookies or sessions to be able to have langage choice (EN-FR-NL) on this site, so that will be for a future version.
Again an update.
This time it was to include few new templates, update of Portuguese translation. The script for Cinéstore was updated, and I just finished to write a script for DVDFR.com
