Display
Gull
Display
Post by Gull »
I have been using this program for many years and it is excellent piece of work. Now suddenly, there is a switch in display. I used to see the list of movies on full screen and when selecting any individual movie, the screen would split sort of half with movies list on the left the credits of the selected movie on the right. But this function has stopped working and nothing happens even if I select a movie. I have tried various options but nothing works. Anyone knows how to go about it? By the way I am using a virtual windows machine on Mac because this software is only available on windows platform. And it has been running fine for 4 or 5 years now.
Re: Display
Maybe you accidentally enabled the "Stretch list" option (F11 or in the "Display" menu) or "Display as grid" (Shift+F4 or also in "Display" menu)
Gull
Re: Display
Post by Gull »
Thanks for the reply. Actually I have tried all options and even re-installed the program but no help. That feature is very useful, I can go around it by switching off thumbnail feature and the information is displayed vertically in columns.
Re: Display
Maybe post a screen capture, I guess something was moved on the screen (as some elements are resizeable and movable)
