Updated version to correct crash on Pentium 4 on Win2000/XP
I recompiled Ant Movie Catalog to correct the problem that lots of people had on Pentium 4 systems.
Replace the .exe of Ant Movie Catalog 3.4.2 with the one that can be found there :
ftp://ftp2.antp.be/antp/temp/amc343.zip
I called it "3.4.3" but there is no new feature.
It should run fine, but I haven't retested everything.
So it would be nice if some people could try it (without "Win98 compatibility" option, of course) before I release it officially.
jj666
Post by jj666 »
I think I missed this - link is dead now?
Thanks for letting me know,
-b-
The link still works for me.
But anyway today I'll publish this update officially ;)
jj666
Post by jj666 »
Many thanks!
The only other bug I can find (which may be a result of using Win 98 compat mode to run the program) - whenever you click a URL from the program, it loads IE6 with the following http://"http://imdb.com/title/tt184894",,-1,0,,,,
which doesn't work :-). When the program exports, it copies the correct link. My previous links (ie. the ones I put in the database before upgrading to Server 2003) work fine still. Pretty wierd huh! :-)
Thanks,
-jj-
Are the quotes in the link in the database, or are they added when you click on the link ?
Official 3.4.3 version :
viewtopic.php?p=5938
jj666
Post by jj666 »
This is the URL copied into IE6
Database just says:-
which works fine when exported etc etc.
Let me try the new version and see if that fixes it.
Cheers!
-jj-
jj666
Post by jj666 »
I can confirm new version fixes startup and URL problem.
(Compatable with Server 2003 also now).
Thanks again,
-jj-
Well, I guess it was the fault of the Win98-compatibility option then, since I did not change anything in the way the URL were launched ;)
