Search & special characters
Kryen
Post by Kryen »
Hello,
Firstly, congrat! This soft is amazing.
I have a suggest:
Add the Windows like special caracter search : " * " " ? " " - " etc..
A exemple for illustrate:
I want to transforme this:
EN-COO-111 - 10 - 2 - 5
into this:
EN-COO-111 - REP10 - QTE2 - EP5
with the specials caracts i'll do this task like this:
Replace * - * - * - *
with * - REP* - QTE* - EP*
Is this possible or not?
regardless, i have some skills on JS and vba VBA so it will be a presure if you need some help :clapping:
ps: FR est ma langue maternelle :)
Re: Search & special characters
Hello,
This is possible using regular expressions (one of Ant Renamer's actions in the list)
These are a little more complicated to use than the * and ?
Check the help file for a basic explanation or https://regex.sorokin.engineer/fr/lates ... sions.html for more info (the link provided in the help file is dead, do not click it, use this link instead).
Otherwise you can easily find tutorials/quick info about these on internet.
French is also my native language but I replied in English in case someone else finds this thread while searching for the same "problem"
