Is it possible to print JPG
systemdown
Post by systemdown »
I am wondering if it is possible to create JPG files with the report designer templates :??: . That would be really nice to add movie info and cover into a CD in JPG format.
Thanks and congratulations for this great software! :grinking:
systemdown
Hello, can somebosy help me? This is really important to me.
Thank you
No, you'll have to put them in BMP.
That's not me that made the report designer (I used a ready-to-use library), and I guess that the one that made it forgot to include Delphi's JPEG support in it.
