New script for startrek.com
DarkInk
Post by DarkInk »
when nobody updates a script, one solution is to create a new one . ;)
You can get it at http://www.darkink.tk.
thanks ;)
BTW, some texts on your site are not visible with Mozilla
e.g. on
http://ciberia.ya.com/darkink/amcscript ... otcom.html
the text is black because Mozilla estimates that the CSS info is more important than the <font> tags (which are obsolete). IE does the opposite.
DarkInk
Thank you
Post by DarkInk »
thanks for this info! I've done a fast fix for Mozilla. When I have more time I'll check it deeper :-)
Merit
Post by Merit »
Hi ! It seems that the link for the script doesn't word at this time (but maybe it's temporarely).
I'll try again later.
Good Job.
DarkInk
Post by DarkInk »
I see.... :angry: The script download only works clicking the link and using Internet Explorer...Why? I don't know. :(
Works with Opera too :D
The problem is that the server wants an HTTP referrer but does not send the correct content-type (bad server :D). That's why it cannot be downloaded with Mozilla.
pbodart
StarTrek script updated ?
Post by pbodart »
Hello,
Does anyone know if it exists an updated version of the StarTrek script ?
It seems that the website has changed, so the scripts reports nothing, or just error. Unfortunately I don't know scripting enough to dig into them and find what need to be modified.
In fact I would like to import in my AMC all the episodes of TNG in batch ... as I own all the DVD's. Does it exists something with a french resume, or the only existing website is the StarTrek.com US website ?
Thanks in advance for your help, and special thanks to Antoine and all the contributors for the great job !
Pierre
Darkink
Post by Darkink »
Well, I see you're right...It seems that my script is not working anymore. I'll try to have a look and update it next week.
I think there's no batch tool to get the information from all episodes. Maybe you can find someone who got all TNG one by one and you convince him to send to you this part of the AMC database. :)
Darkink
Post by Darkink »
Curiosity...I could not wait until next week... :lol:
Script is working again. Fortunately only little changes in www.startrek.com.
You can download it from www.darkink.tk. :grinking:
pbodart
Many many thanks
Post by pbodart »
Thank you very much :)
Great work, great community :)
Pierre
Excellent script, thank you very much!
BTW, season 4 of Enterprise is currently airing.
Easy to fix manually, but it should be taken into account for the next script update. ;)
DarkInk
Post by DarkInk »
you are right, thank you for the information. I've added Enterprise Season 4. :)
