Insert utility
pollopolea
Insert utility
Post by pollopolea »
first I must say that im spanish and my englist isn´t good at all.
I use you program an it very usefull , but some I see it needs a feature:
- Insert funtion: you select a movie and you can write the position in which you want to insert it, the rest of the movies renumber.
thanks!!
Actually it is possible to renumber the movies using a script.
Select the movies that have to get their number incremented by 1, then go to Tools -> Scripting -> Editor -> New
and past the following script :
// SCRIPTING
program AddOne;
  SetField(0, IntToStr(StrToInt(GetField(0), 0) + 1));
Click Run.
Then when you come back to the movie list you'll maybe have to refresh it (right click -> Refresh).
