some extra fields needed?
sorinm
Post by sorinm »
Wouldn’t be useful to have some extra fields about:
-color. I mean I have plenty of old and very good movies b/w and I want to accentuate that.
-awards & nominations - very important for a cinema-goer
What are your opinions?
you should check the topic at the top of the list,
viewtopic.php?t=684
:p
Ok, thank you.
