Weird behavior with 2 movies with same name
elman
I just add new The Texas Chainsaw Massacre to my catalog and since I also have the old one, now I have 2 movies with same name. Program doesn't generate any error, however its behavior is weird. Program switches order of the movies twice after every action. Try to sort movies by name and then use arrows to move up and down in the list and you will see how program changes order of those two films. This behavior also can be seen when editing any movies and tab is used to jump to the next field. This switching doesn't occur if one one movie is visible in the list. I have 850 Mhz computer, so it might be so fast you won't notice it on fast machines.
