Script to Renumber Movies
al0203
Post by al0203 »
Hi, I don't find the function to renumber movies inside an script.
There are some scripts that need the movies to be order in an specific way, before you run it. I would need a function to renumber the movies, so when I run those scripts, the first line of the script would order the movies in the correct way and I wouldn't need to previouslly order it manually.
Thank you.
Re: Script to Renumber Movies
In main menu,
Tools -> Renumber.
:shocked:
I don't know any function inside scripts.
al0203
Post by al0203 »
fulvio53s03 wrote: 2020-05-28 18:39:24 In main menu,
Tools -> Renumber.
:shocked:
That's what I ment manually and that's what I want to avoid.
Thank you.
