Add movie files as a separate movie simultaneously
Silver Ghost
Post by Silver Ghost »
Thanks for great catalog!
but may be I am stupid and it is already possible... it would be fine to have a posibility to get a movie information from lot of files as a separate movies simultaneously...
You mean import information from internet for more than one movie ?
Select the movies in the list (you have to already have at least the titles) and click Tools -> Scripting
Silver Ghost
I mean the import of the information from the file...
for example I have the empty catalog and the disk with a 30 movies (30 single avi-files). And one file is one independent movie. Now I want to add the info from each file as single movie... If I choose all of them together in the selection window, I will recive 1 movie which consist from 30 files... But this is not what I really want. I want to have 30 movies... Therefore I need to repeat "add movie information from file" 30 times... It is quite difficult with 1000 files for example...
Anyway I tested a lot of programs and find yours the best one (powerfull and convenient)
:) sorry for my stupid English... :)
There is a trick :
viewtopic.php?t=229
