Exportar listas de impresion - to export impression lists
Lionel
Post by Lionel »
Hola amigos.
Mi proposición es que se pueda exportar el formulario de impresión (“List1” o “List2”) a un documento de Word o PDF.
Esa lista sería mucho mejor que un TXT o CSV
Mi ingles es bastante malo y mi francés nulo así que disculpad cualquier error en este post.
Muchas gracias.
Hello friends.
My proposition is that the form of impression ("List1" or "List2") may be exported to a document of Word or PDF.
That exported list would be much better than a TXT or CSV
My English is quite bad and my French worse so dispense any error in this post.
Thank you very much.
It is not possible to export correctly to Word, but you can easily export to PDF.
You just have to install a PDF Printer Driver and print to it.
http://sector7g.wurzel6-webdesign.de/pd ... dex_en.htm
