IMDB Importing Studio Or Production Company.
raeditani93
Post by raeditani93 »
Hello,
How to get or import studio or production company from imdb.
Any Help.
And DVDEmpire doesn't show name of the movie in the search window. Why??
Thanks.
Re: IMDB Importing Studio Or Production Company.
It does not look like it is part of the few options of the script, so one would have to modify the script to add that.
For DVDEmpire, it looks like your script is outdated: try running the "update scripts" script at the top of the list to get the latest version.
raeditani93
I've already got the latest version. (DVDEmpire)
I hope someone can add the feature for the script. (IMDB)
Thanks in advance.
For DVDempire I had the same problem with the old version and it had been solved when upgrading it :??:
Do you have version 2.2.8 of the script? For me it works fine.
raeditani93
Thanks it worked. :clapping:
I already updated the script but there was something wrong.
I'm still waiting to add feature to script of imdb.
Thanks again for ur help. :)
