Edit Fields
raeditani93
Edit Fields
Post by raeditani93 »
Hello,
Can we edit multiple info for different movies at the same time. (Fields).
Thanks..
Re: Edit Fields
Via Tools->Scripting, there is a script named "update all fields" which offers various options, and which can be applied either to all movies or only the selected ones (see options in the panel on the right).
It can also be done manually with a basic script, see viewtopic.php?f=5&t=8285&p=46086
raeditani93
Re: Edit Fields
Thanks it worked. :clapping:
