problem running imdb scripts
First, congratulations for your program. It's excelent.
Unfortunately, since yesterday, the imdb scripts stop working. Did it happen with someone eles? is there a way of dealing with it?
Regards,
Ricardo Correia Duarte
Porto, Portugal
http://pwp.netcabo.pt/ricardo-duarte/
What's the problem, and with which movie(s) ?
Hi, I'm sorry for not answering sooner.
The problem is when you place the name of the movie, than chose Shift-F10 to run the script and there's no results from the imdb scripts...
Here's a picture of the results of the script:
http://pwp.netcabo.pt/ricardo-duarte/pic.jpg
Regards,
Porto, Portugal
http://pwp.netcabo.pt/ricardo-duarte[/url]
Regards,
Porto, Portugal
It seems to work fine here. Have you tried to get the latest version of the scripts on my site ?
ricduarte
Post by ricduarte »
Thanks for the prompt answer. I'll download your latest pack and come back to you with feedback.
Again, thanks, AMC is indeed great.
Regards,
Ricardo
ricduarte
Post by ricduarte »
Hi again,
Having downloaded the latest pack, the problem persists, although, the outcome is slightly different, as you can see:
http://pwp.netcabo.pt/ricardo-duarte/pic2.jpg
I'm using for now the all movie guide script.
Regards
Both IMDB and All Movie Guide scripts work fine with this movie too.
How did you update the scripts ?
If you used the "scripts" zip file, be sure that you expanded to AMC main folder and not in the scripts folder, since the zip file already contains a "scripts" folder.
ricduarte
Post by ricduarte »
I just downloaded the "Complete package with installation" (Size: 3255 KB, Last update: 2003-11-01), which I believe to have the latest scripts...
And yet, it doesn't work for me... and also for several friends of a binaries mailing list I belong to.
Strange, isn't it? could it be some problem with our ISP, which I think uses a proxy?
Ricardo
I do not know :(
ricduarte
Post by ricduarte »
well, thanks anyway for your support. if you need a beta tester in the future, I'll be glad to help...
Regards,
Ricardo
Yes, I have the same problem here. Script only gives the imdb url. I have downloaded the latest version and still, the same problem. :(
Greetings
IMDB changed their site since yesterday :
viewtopic.php?t=1080
