Importing Playtime from Files
When importing playtime from video files - this works fine. But if importing the playtime twice, its added to the first value. So a movie of 100 minutes gets longer and longer per import.
toxic
Post by toxic »
add:
this means it then is 200 or 300 and so on minutes long...think this would be not so importent but easy to fix
It is a feature : if you have a movie on multiple files you have to be able to import length of each files.
