Problem with Printing
RW
Post by RW »
Hallo,
I'm using the Movie Catalog, but I have a problem with printing.
I have designed an new Report in DIN A5. When I want to print the preview shows all filds correct, including the number. But when I push the button print, the windows appears new an the numberfield is empty. In the print the field is also emty.
Can You help me?
What do you call "numberfield" ? Maybe that there is text too close to the margin of the page ?
RW
Post by RW »
In a rectangle object I use the Variable [NUMBER].
When you say "the window appears new", what does it mean ?
You print from AMC preview window ? If you try to print from the report designer it won't work.
