Problems with printing
Oluap
Post by Oluap »
I use Ant Movie Catalog (superb program) and created 2 movie databases. When I try to print it the 1 of the database the program just quits without warning :cry:
That's very strange... How big is the database ? (number of movies, file size, ...)
Did you try to create a new file and import the database in it ?
Oluap
Post by Oluap »
Thanks for the quick answer. The database with this problem contains 50 movies. The other one (can print normally) has about 45 movies. I reinstall the amc and the problem continues.
Hi!
The problem disappears when I delete the movie "Animatrix" from the database.
Oluap
Post by Oluap »
Sorry I forgot to log in
Hi!
That's quite strange...
Maybe there was character that it did not like in one of the fields
vinni
bug in printing
Post by vinni »
Yep, I add the same issue with Animatrix. But I found the origin of the problem: there were two many characters in teh "Actors" field for the print to work. I chopped off most of the names and it went fine afterwards. One more thing to check ...
Thanks anyway for this tool, it really is a step up from my Excel file !
Cheers.
Re: bug in printing
vinni wrote:One more thing to check ...
yes, that's strange
