New Language
CAMED
New Language
Post by CAMED »
Hello Ant Renamer Team
Since 2012 I'be used this useful software and I'd like to help translating to Spanish (Colombia, South America) language. ;)
I can translate the language and help files. :)
Please, let me know if you are interested. :grinking:
Regards, Carlos
Re: New Language
Sure, but are there so many differences?
There is already a variant for Argentina, would it differ also from that one?
If you want to translate it, simply go to the "Languages" folder of the program and copy one of the .lng file to another name and then edit it with a text editor (Notepad, ...)
CAMED
Re: New Language
Post by CAMED »
Hello,
The Argentina's variant had a couple of mistakes.
I guess I fix it and adapted more to a neutral language.
Here you can find the language file:
https://drive.google.com/open?id=1pb1f4 ... esTCvEI4Y9
Re: New Language
Thanks, I'll try to find some time at some point to update the install files to include it ;)
