Sorting
Hawkie
Sorting
Post by Hawkie »
Hi!
Could you please add an option to the export function, so I could order the titles by ascending or descending order. I want to sort the movies by the year, newer first (2002,2001...) and I can't do this without this option.
I plan to add this option, I will do that when I've time for that. I hope that it will be possible for the final version of version 3.4
Seems that you didn't have time to put it in 3.4 Final. Maybe in a 3.5 version ?
there will probably not be a 3.5 version, you'll have to wait for 4.0
Since it will require a big change in the sorting functions and windows, I prefer to wait for version 4 since this version will required this kind of changes anyway.
