new italian scripts update
I want to inform all italian users that you can find the updated version of the italian scripts at this address:
http://forum.doom9.it/viewtopic.php?t=2 ... ie&start=0
Please note that the script that are actually used in amc for "Filmup.it" and "Cinematografo.it" works parctially because the original sites was changed while the improved versions at the address above works perfectly.
I hope that these versions will be enclosed in the next release of AMC
Re: new italian scripts update
Anonymous wrote: I hope that these versions will be enclosed in the next release of AMC
Sure.
I guess that the scripts that I have to include are these two :
http://forum.doom9.it/viewtopic.php?p=28155#28155
http://forum.doom9.it/viewtopic.php?p=28581#28581
robgarib
Post by robgarib »
Yes, i confirm that these are the updated scripts to insert in AMC.
The script for "Cinematografo.it" replace the actual script in AMC
that doesn't works anymore because the site has changed.
The script for "Filmup.it" is more powerful respect to the actual script in AMC because extract from the site the comments and other informations too.
I have done another modifies to the script of Cinematografo.It modifying the selection of Search. The old script sought all the titles of film that contained "the string" in the title. Often, when a short title was sought (example LEON), the search could give many results. The change allows to seek Only the Title that has The String instead. If it interests you I copy you the modified Script.
Bye bye. Destroyer76 ;)
Ho fatto un'altra modifica allo script di Cinematografo.it, modificando la selezione di Ricerca. Il vecchio script ricercava tutti i titoli di film che contenevano "la stringa" nel titolo. Spesso, quando si ricercava un titolo corto (esempio LEON), la ricerca poteva dare molti risultati. La modifica invece permette di ricercare SOLO il Titolo che ha quella stringa. Se vi interessa vi copio lo Script modificato.
Ciao ciao. Destroyer76 ;)
Sarebbe ottimo
grazie
It would be nice
Eccoti lo script modificato....
Spero ti possa essere utile.
Ciao ciao.
// GETINFO SCRIPTING
// Cinematografo.it
*  Cinematografo.it, http://www.cinematografo.it  *
* (c) 2003 Andrea Cristaudo achris@tiscalinet.it  *
*  For use with Ant Movie Catalog 3.4.1           *
* 30/10/2003 Modificato da Zandal per cambio      *
*            gestione indirizzi pagine            *
*            su Cinematografo.it                  *
* 29/12/2003 Modificato da Destroyer76 per        *
*            eseguire la la ricerca del Titolo    *
*            su una STRINGA IDENTICA a quella     *
*            Inserita, per evitare di avere molti *
*            risultati quando la STRINGA di       *
*            ricerca è contenuto in molti film.   *
program Cinematografo;
  TheMovieAddress: string;
function RemoveTabs(Pattern: string): string;
    Delete(Pattern, 1, 1);
  until ord(copy(Pattern, 1, 1)) <> 9;
  result := Pattern;
function Space2html(Url: string): string;
  Temp : string;
  SpacePos : Integer;
    SpacePos := pos(' ', Url);
    if SpacePos <> 0 then
        Temp := copy(Url, 1, SpacePos -1);
        Delete(Url, 1, SpacePos);
        Temp := Temp + '%20' + Url;
        Url := Temp;
  until pos(' ', Url) = 0;
  result := Url;
function FillInput(Page: TStringList; LineNr: Integer; Salto: Integer; Field: Integer): Integer;
  LineNr := LineNr + Salto;
  Line := StringReplace(Page.GetString(LineNr), '<BR>', #13#10);
  HTMLRemoveTags(Line);
  HTMLDecode(Line);
  Line := Trim(RemoveTabs(Line));
  if Field = fieldActors then
    Line := StringReplace(Line, '      ', ' : ');
    Line := StringReplace(Line, ' ', ' ');
  SetField(Field, Line);
  Result := LineNr;
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
      result := i;
  LineNr: integer;
  BeginPos: integer;
  LineNr := FindLine('DELLA RICERCA', Page, 0);
  if LineNr = -1 then
    LineNr := FindLine('<b>La vostra richiesta non trova risposta nell''archivio.</b>', Page, 0);
    if LineNr = -1 then
      AnalyzeMoviePage(Page);
      ShowMessage('Nessun film trovato');
//    input ('test','test',page)
    AddMoviesTitles(Page);
    if TheMovieAddress='' then
  Fine: Integer;
  BeginPos, EndPos: Integer;
  Field: integer;
  Fine := 0;
//  LineNr := FindLine('<strong>Titolo Film</strong>', Page, 0);
  LineNr := FindLine('<font color="#ffffff">Titolo Film</font>', Page, 0);
  if LineNr > -1 then
    //Translated Title
    LineNr := LineNr + 5;
    Line := RemoveTabs(Line);
    LineNr := LineNr + 3;
    if pos('<img border="0" src="', Line) <> 0 then
      BeginPos := pos('<img border="0" src="', Line);
      Delete(Line, 1, BeginPos + 20);
      EndPos := pos('" ', Line);
      Line := copy(Line, 1, EndPos - 1);
      Line := StringReplace(Line, ' ', '');
      Line := 'http://www.cinematografo.it/bdcm/' + Line;
      Line := Space2html(Line);
      GetPicture(Line, False);
      LineNr := LineNr + 1;
      if pos('<font color="#ffffff">Anno</font>', Line) <> 0 then
        LineNr := FillInput(Page, LineNr, 3, fieldYear)
      else if pos('<font color="#ffffff">Titolo originale</font>', Line) <> 0 then
        LineNr := FillInput(Page, LineNr, 3, fieldOriginalTitle)
      else if pos('<font color="#ffffff">Durata</font>', Line) <> 0 then
        LineNr := FillInput(Page, LineNr, 3, fieldLength)
      else if pos('<font color="#ffffff">Origine</font>', Line) <> 0 then
        LineNr := FillInput(Page, LineNr, 3, fieldCountry)
      else if pos('<font color="#ffffff">Genere</font>', Line) <> 0 then
        LineNr := FillInput(Page, LineNr, 3, fieldCategory)
      else if pos('<font color="#ffffff">Produzione</font>', Line) <> 0 then
        LineNr := FillInput(Page, LineNr, 3, fieldProducer)
      else if pos('<font color="#ffffff">Regia</font>', Line) <> 0 then
        LineNr := FillInput(Page, LineNr, 3, fieldDirector)
      else if pos('<font color="#ffffff">Trama</font>', Line) <> 0 then
        LineNr := FillInput(Page, LineNr, 3, fieldDescription)
      else if pos('<font color="#ffffff">Critica</font>', Line) <> 0 then
        LineNr := FillInput(Page, LineNr, 3, fieldComments)
      else if pos('<font color="#ffffff">Attori</font>', Line) <> 0 then
        LineNr := FillInput(Page, LineNr, 3, fieldActors)
      else if pos('<img align="right" border="0"', Line) <> 0 then
          BeginPos := pos('<img align="right" border="0" src="', Line);
          Delete(Line, 1, BeginPos + 35);
          EndPos := pos('">', Line);
          Line := 'http://www.cinematografo.it/' + Line;
      else if pos('</table>', Line) <> 0 then
        Fine := 1;
    until Fine = 1;
  DisplayResults;
  TheMovieAddress := '*';
  LineNr := 0;
//  LineNr := FindLine('<a href="/dati/scheda.asp?sch=',Page,LineNr);
  LineNr := FindLine('<a href="bancadati_scheda.asp?sch=',Page,LineNr);
  while LineNr > -1 do
    BeginPos := pos('<a href="',Line)+9;
    Delete(Line, 1, BeginPos-1);
    BeginPos := 1;    //pos('<a href="',Line)+9;
    EndPos := pos('">',Line);
    MovieAddress := 'http://www.cinematografo.it' + '/bdcm/' + copy(Line,BeginPos,EndPos-BeginPos);
    MovieTitle := Line;
    HTMLRemoveTags(MovieTitle);
    HTMLDecode(MovieTitle);
    MovieTitle := RemoveTabs(MovieTitle);
//    LineNr := LineNr + 5;
//    Line := Page.GetString(LineNr);
//    input ('test1','testfilm',Line);
//    HTMLRemoveTags(Line);
//    input ('test2','testfilm',Line);
//    Line := RemoveTabs(Line);
//    input ('test3','testfilm',Line);
//    MovieTitle := MovieTitle + ' (' + Line + ')';
    LineNr := FindLine('<a href="bancadati_scheda.asp?sch=',Page,LineNr+1);
//    LineNr := FindLine('<a href="/dati/scheda.asp?sch=',Page,LineNr+1);
    if TheMovieAddress='*' then
      TheMovieAddress := MovieAddress
      TheMovieAddress := '';
Var
  TempVar: String;
  if CheckVersion(3,4,1) then
    if Input('Cinematografo.it', 'Enter the title of the movie:', MovieName) then
//      TempVar :='http://www.cinematografo.it/bdcm/bancadati_query.asp?fi='+UrlEncode(MovieName)+'&R1=TI&x=27&y=16';
        TempVar :='http://www.cinematografo.it/bdcm/bancadati_qrysrcfld.asp?tifilmopt=UGUALE&tifilm='+UrlEncode(MovieName)+'&R1=TI&x=27&y=16';
//      AnalyzePage('http://www.cinematografo.it/bdcm/bancadati_query.asp?fi='+UrlEncode(MovieName)+'&R1=TI&x=27&y=16') //'&submit1=++Cerca++');
      analyzepage(TempVar)
    ShowMessage('This script requires a newer version of Ant Movie Catalog (at least the version 3.4.1)');
Please note that the script for "35mm.it" doesn't works anymore and crashes Amc.
I have noted too that the script for "Cinematografo.it" now works partially.
There is someone that can update these script and post them here?
Thanks in advance.
Volevo avvisare the lo script per 35mm. non funziona più e blocca Amc.
Ho anche notato che lo script per Cinematografo ora funziona parzialmente.
C'è qualcuno che può aggiornare questi scripts e postarli qui?
Grazie in anticipo.
Anonymous wrote:Please note that the script for "35mm.it" doesn't works anymore and crashes Amc.
It does not crash, it is only an endless loop that can be stopped by clicking the "Stop" button of the toolbar.
For the moment I do not have time to correct these scripts, so if somebody else can do it, it would be nice :)
