[NL] Script aanmaken
Seniorke
Post by Seniorke »
Wie kan mij soms helpen of uitleggen hoe ik een script kan maken.
Bestaat er soms een handleiding of ... ???
Alvast bedankt voor de hulp
mvg Seniorke
Please write topics in English (or in French)
GUEST
NL
Post by GUEST »
[NL] Is NEDERLANDS een verboden taal?
[EN] Is DUTCH a prohibited language?
[FR] Le NEERLANDAIS, est elle une langue interdite?
:angry: :angry: :angry: :angry: :angry: :angry: :angry:
If everybody writes here in his language, only few persons can read it.
So default language is English. You'll get much more answers if you write in English than in Dutch.
Since there are lots of French users, and that I can understand French, I also accept that they post in French.
Do not forget that :
- It is usually me that answer the questions that user ask
- This forum is on my server, so I have a part of responsability in what is said here... I prefer to understand what is said !
Re: [NL] Script aanmaken
Seniorke wrote:Wie kan mij soms helpen of uitleggen hoe ik een script kan maken.
mvg Seniorke
In English he asked:
Who can help or explain to me how to make a script.
Is there maybe a manual or ... ???
Thanks in advance for helping me
Im curious too, because the Cineguide NL and the Moviemeter script does'nt do anything. Maybe somebody can fix these scripts ?
Moviemeter cannot be fixed because now it requires that the program does a POST request to the server instead of GET, and current version of AMC does not work for that.
About Cineguide I do not know, I should check it because I do not remember what was the problem.
Tj
Post by Tj »
Thanks for the quick response.
I really hope you can fix cineguide, because there is'nt any Dutch language site left.
Maybe you can make a script for: http://www.video.nl
On this site you can search for movie info too, all in Dutch.
Tj
This site also uses POST to submit data :/
For this one you will also have to wait for AMC 4, unfortunately
Hmmm.
It's not easy to find a good Dutch info site. I try to find some more, maybe is there one lucky site that does'nt need AMC4.....
If not... I have patience for the AMC4, till then i'll use the English sites. In the future I can still update them to Dutch.
Anyway, thanks for the efford you put in to make this good (and Freeware !) program.
TJ
Seniorke
Post by Seniorke »
I found a site with useful information but I cant write a script.
The site http://www.bseendvd.nl/
Can sombody write a script for this site.
For this site it may be possible.
The URL to use to make the search is
http://www.bseendvd.nl/shop/search.php? ... searchstr=***
where *** is the title of the movie
Thx
But how I must do the rest to put the fields I needed in the script.
mayby this one www.moviecity.nl is posible ?
Seniorke
dutch sites
Post by Seniorke »
We are DUTCH speaking. Nobody will or can help us.
:lol: :lol: :lol: :lol:
gast spreker
script's voor nederlandse site's
Post by gast spreker »
Ik hou me aanbevolen als iemand een script heeft voor welke nederlandse site dan ook :)
Verder een top programma, maar jammer dat er aan de hollanders (weer) niet word gedacht.
Seniorke
DUTCH language
Post by Seniorke »
Beste Gast spreker
Het is zoals gewoonlijk nederlands sprekende worden uitgestoten.
Het is een pracht van een programma waar nederlandstaligen ook zouden kunnen van gebruik maken maar ja wie zijn wij?
Nu zal er een reply volgen dat het in Frans of Engels moet.
Het zal me worst wezen.
mvg Seniorke
I cant write it in frensh or english. The Dutch speaker can understeat it.
Dear admin,
THXS!!! it works. Sorry but my english is bad :(
You help a lot off Dutch people with this ;)
En voor de Nederlands sprekende, het werkt.
ff script over kopieen in de oude script.
Greetings ;)
ROINBINHOODpot
scripts for Cineguide NL
Post by ROINBINHOODpot »
Those scripts do'nt work, the http://www.cineguide.be is'nt a good database, better concentrate on moviecity.nl
So I'll have to update it again.
You say that it is not good, but some people like it.
And I prefer to correct existing scripts than create new ones, leaving old not working scripts.
For moviecity.nl it seems not possible : it uses POST instead of GET to submit searches.
